mypooka
Member level 1
16f84 maths
:lol:
maybe these are usefull for some newer people
i set these maths routines up for 16f84
16bit maths division, subtraction, multiplication!
hope these help someone!
list P = 16F84
include "p16F84.inc"
CBLOCK 0x0C
ACCaLO
ACCaHI
ACCbLO
ACCbHI
ACCcLO
ACCcHI
ACCdLO
ACCdHI
temp
sign
ENDC
; Double Precision Division
; Load constant values to ACCa & ACCb for testing
org 0h
movlw 0h
movwf ACCaHI ; the dividing number!
movlw d'10' ; after run! loads ACCa = FF= d15
movwf ACCaLO
movlw 015
movwf ACCbHI ; the number to be divided!
movlw 07C ; also the result of division
movwf ACCbLO ; load eg: 157C = d5500
call D_divS ; remainder in ACCc
; remander =63
stop goto stop
D_divS
call setup
clrf ACCcHI
clrf ACCcLO
dloop bcf STATUS,C
rlf ACCdLO, F
rlf ACCdHI, F
rlf ACCcLO, F
rlf ACCcHI, F
movf ACCaHI,W
subwf ACCcHI,W ;check if a>c
btfss STATUS,Z
goto nochk
movf ACCaLO,W
subwf ACCcLO,W ;if msb equal then check lsb
nochk btfss STATUS,C ;carry set if c>a
goto nogo
movf ACCaLO,W ;c-a into c
subwf ACCcLO, F
btfss STATUS,C
decf ACCcHI, F
movf ACCaHI,W
subwf ACCcHI, F
bsf STATUS,C ;shift a 1 into b (result)
nogo rlf ACCbLO, F
rlf ACCbHI, F
decfsz temp, F ;loop untill all bits checked
goto dloop
retlw 0
setup movlw 0x10 ; for 16 shifts
movwf temp
movf ACCbHI,W ;move ACCb to ACCd
movwf ACCdHI
movf ACCbLO,W
movwf ACCdLO
clrf ACCbHI
clrf ACCbLO
retlw 0
END
list P = 16F84
CBLOCK 0x0C
temp
ACCaLO ; was called product!
ACCaHI
ACCbLO
ACCbHI ; first x number
ACCcLO ; second number!
ACCcHI
ENDC
org 0h
; multiply sub rutine!
goto $ +4
clrf ACCaLO
clrf ACCaHI
nop
nop
clrf ACCaLO
clrf ACCaHI
movlw 0x0A
movwf ACCbLO ; lower 8bits of first number
movlw 0x00
movwf ACCbHI ; upper 8bits of first number
movlw 0x6F
movwf ACCcLO ; lower 8bits of second number
movlw 0x19
movwf ACCcHI ; upper 8bits of second number
movlw .16 ; Operating on 16 Bits
movwf temp
Loop ; Loop Here for Each Bit
rrf ACCbHI, f ; Shift the Multiplier down
rrf ACCbLO, f ; by one
btfss STATUS, C ; If the bit is set, add
goto Skip ; the Multiplicand to the
; "Product"
movf ACCcHI, w
addwf ACCaHI, f
movf ACCcLO, w
addwf ACCaLO, f
btfsc STATUS, C
incf ACCaHI, f
Skip ; Shift up Multiplicand and
bcf STATUS, C ; Loop Around
rlf ACCcLO, f
rlf ACCcHI, f
decfsz temp,F
goto Loop
; the result is in ACCaHI,ACCaLO
stop goto stop
end
list P = 16F84
CBLOCK 0x0C
temp
ACCaLO ;
ACCaHI
ACCbLO
ACCbHI ; first number
ACCcHI
ACCdLO
ACCdHI
ENDC
; subtract sub rutine!
org 0h
; test code for subtraction
movlw 0x8A
movwf ACCaHI ; example numbers
movlw 0x06
movwf ACCaLO
movlw 0x8A
movwf ACCbHI
movlw 0x0A
movwf ACCbLO
movf ACCaHI,W ; Subtract the High Byte First
subwf ACCbHI,W ; b-a=c
movwf ACCcHI ; store the HI results
movf ACCaLO,W ; Subtract the Low Byte Next
subwf ACCbLO,W ; store the result in ACCbLO
movwf ACCcLO ; store the LO results
btfss STATUS, C ; Don't Dec high byte if carry Set
decf ACCcHI, F
iorwf ACCcHI, W ; Check for Equal to Zero
btfsc STATUS, Z ; If Not Zero, Jump Over
goto EqualLess ; Equals, Jump to the Code
btfsc ACCcHI, 7h ; If Number is Negative, execute
goto EqualLess ; if A>B go here! Else, Jump Over
great goto great ; if A<B go here!
; results are in ACCcHI and ACCcLO
EqualLess
stop goto stop ;
end
:lol:
list P = 16F84
CBLOCK 0x0C
ACCaLO
ACCaHI
ACCbLO
ACCbHI
ACCcLO
ACCcHI
ACCdLO
ACCdHI
temp
sign
ENDC
org 0h
movlw 0h
movwf ACCaLO
movlw 015
; remander =63
stop goto stop
D_divS
call setup
clrf ACCcHI
clrf ACCcLO
dloop bcf STATUS,C
rlf ACCdLO, F
rlf ACCdHI, F
rlf ACCcLO, F
rlf ACCcHI, F
movf ACCaHI,W
btfss STATUS,Z
goto nochk
movf ACCaLO,W
goto nogo
subwf ACCcLO, F
btfss STATUS,C
decf ACCcHI, F
movf ACCaHI,W
subwf ACCcHI, F
nogo rlf ACCbLO, F
rlf ACCbHI, F
goto dloop
retlw 0
movwf temp
movwf ACCdHI
movf ACCbLO,W
movwf ACCdLO
clrf ACCbHI
clrf ACCbLO
retlw 0
END
list P = 16F84
CBLOCK 0x0C
temp
ACCaHI
ACCbLO
ACCcHI
ENDC
org 0h
goto $ +4
clrf ACCaLO
clrf ACCaHI
nop
nop
clrf ACCaLO
clrf ACCaHI
movlw 0x0A
movlw 0x00
movlw 0x6F
movlw 0x19
movwf temp
; "Product"
movf ACCcHI, w
addwf ACCaHI, f
movf ACCcLO, w
addwf ACCaLO, f
btfsc STATUS, C
incf ACCaHI, f
rlf ACCcLO, f
rlf ACCcHI, f
decfsz temp,F
goto Loop
stop goto stop
end
list P = 16F84
CBLOCK 0x0C
temp
ACCaLO ;
ACCaHI
ACCbLO
ACCcHI
ACCdLO
ACCdHI
ENDC
org 0h
movlw 0x8A
movlw 0x06
movwf ACCaLO
movlw 0x8A
movwf ACCbHI
movlw 0x0A
movwf ACCbLO
decf ACCcHI, F
EqualLess
stop goto stop ;
end
