16 bit 16 channel ADC in DIP package
gooofy871
Member level 2
Member level 2
Hi all..
I am right now working on a project which requires a 16bit 16 channel ADC.. I got the same from many websites. But the problem is non of them is providing DIP package of the ADC. I would like to do a proof of concept test on a bread board before actually fabricating the PCB...
So is there any ADCs available in the spec?? or suggest me another way..
Thanks in advance..
Do you wish a 16 channel 16 bit solution on a chip pls or are you searching for siple 16 bit ADCs?
Such can you have over 10-15 years & at 100Ksps up tu 2Msps...
Or if you need 24 Bit,or more, S--D chips are up to 10-100Hz Bandw. tu buy...
Check by google & ADI, TI, NI, and so on:)
K.
I have already checked for the same but the problem is every body is providing a Quad Flat package of Pin.. I wish to test my design 1st in a bread board and make sure my concept is fine which requires a Dual InLine Package, and then go for a PCB fabrication using Quad Flat package. I need an ADC which is available in both Quad flat and DIP package..!!! I could find one like this..!!
Or is there any other way I can go for a Proof of Concept other than a bread board?? How reliable will be software simulation of the design compared to a test in bread board? Could anyone recommend a good software for the same.
Re: 16 bit 16 channel ADC
can you do a quad flat to dip converter?
gooofy871 said:
...Or is there any other way I can go for a Proof of Concept other than a bread board?? How reliable will be software simulation of the design compared to a test in bread board? ...
Of course, you can adapt your QFP to Dip, otherwise wil your selections spectrum really smaller!....
All simulators are max. so good as the modells!:-(
For me is the best verification _often the only one_ is a "knowed" measurement!
Good luck!
K.
Thanks @ karesz @wpchan05
