guesslsc85
Newbie level 5
movlw assembly
I am currently working with Infrared Perimeter/Gate that use RC5 coding. Could anyone help to change the source code of decoder part in order to suite my application(IR gate/fence). What I needed to do is to continuously monitor the encoded IR light and the output of decoder will be an LED or alarm.
When the IR light is obstructed by someone, the LED/alarm will turn on. Otherwise , it will be turned off.
Attached is the decoder part source code.
Thanks for helping.
http://www.sixca.com/eng/articles/remote/3ch_remote.zip
Thanks for helping.
[code];--------------------------
; THIS IS RX
; PROJECT :3 channel remote control
; CRYSTAL 4 MHz
; RC5 FORMAT @38KHz , 35% duty cycle
; ADDRESS = 0X0B
; ch1 = 0X01
; ch2 = 0X02
; ch3 = 0X03
; NOT USE TOGGLE ALWAY = 0
; 4-JULY-2005
list P=12F629
#include <P12F629.INC>
__config _WDT_OFF & _XT_OSC & _CP_ON & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _PWRTE_ON
#DEFINE IR GPIO,3 ; IR LED input with R10K pull-up to vcc
#DEFINE OUT1 GPIO,0 ; Drive output 1
#DEFINE OUT2 GPIO,1 ; Drive output 2
#DEFINE OUT3 GPIO,2 ; Drive output 3
#DEFINE OUT1_M 0x01
#DEFINE OUT2_M 0x02
#DEFINE OUT3_M 0x04
#DEFINE TOG_BIT TOGGLE,0
#DEFINE ADDRS 0X0B ; 0000 1011 ; 0000 1110
#DEFINE CH1_CMD 0X01
#DEFINE CH2_CMD 0X02
#DEFINE CH3_CMD 0X03
CNT1 EQU 20H
CNT2 EQU 21H
CNT3 EQU 22H
CNT4 EQU 23H
TEMP EQU 24H
TOGGLE EQU 25H
ADDR EQU 26H
CMD EQU 27H
ORG 000
;BSF STATUS,RP0
;CALL 0X3FF
;MOVWF OSCCAL
;BCF STATUS,RP0
CALL DEBOUNCE
MOVLW 0X07
MOVWF CMCON ; MAKE ALL GPIO TO DIGITAL I/O
BSF STATUS,RP0
MOVLW 0X01
MOVWF OPTION_REG
MOVLW B'00001000'
MOVWF TRISIO
CLRF IOCB
BCF STATUS,RP0
BCF INTCON,GIE
CLRF GPIO ; turn off all output
MAIN: CALL DELAY3500
CALL GET_RC5
BTFSC STATUS,C
GOTO MAIN
MOVF ADDR,W
XORLW ADDRS
BTFSS STATUS,Z
GOTO MAIN ; ADDRESS ERROR
MOVF CMD,W
ANDLW 0X03 ; MASK 2 LSB
ADDWF PCL,F
GOTO MAIN ; COMMAND 0X00 NOT USE OR COMMAND ERROR
GOTO DO_CH1
GOTO DO_CH2
GOTO DO_CH3
DO_CH1: MOVLW OUT1_M
GOTO CHANGE
DO_CH2: MOVLW OUT2_M
GOTO CHANGE
DO_CH3: MOVLW OUT3_M
CHANGE: XORWF GPIO,F [quote];need to change here or elsewhere...[/quote]
GOTO MAIN
; READ RC5 Format
; OUTPUT : TOGGLE.7 = TOGGLE BIT
; ADDR = ADDRESS 5 BIT
; CDM = COMMAND 6 BIT
; C = 0 READ OK
; = 1 READ ERROR
GET_RC5:BTFSC IR
GOTO GET_RC5 ; WAIT IR LOW
CLRF TMR0 ; clear timer 0
NOP
BCF INTCON,T0IF ; CLR timer 0 flag
NOP
BTFSC INTCON,T0IF
GOTO ERR1
BTFSS IR
GOTO $-3
MOVF TMR0,W
;MOVLW 0xC8 ; FOR TEST
MOVWF TEMP
MOVLW 0XFF ; 1020 mS = 255*4
SUBWF TEMP,W
BTFSC STATUS,C
GOTO ERR1 ; ERROR IF Time > 1020 uS
MOVLW 0XC8 ; 800 mS
SUBWF TEMP,W
BTFSS STATUS,C
GOTO ERR1 ; ERROR IF Time < 800 uS (C8h * TM0 Prescaler = 800 uS )
BTFSC IR ; Time validate 800uS-1020uS
GOTO $-1 ; WAIT TO LOW (Syn BIT)
CALL DELAY1252 ; DELAY 3/4 BIT LENGHT=1252 uS
BTFSS IR
BCF TOGGLE,7
BTFSC IR
BSF TOGGLE,7
BTFSS IR
GOTO $+4
BTFSC IR
GOTO $-1
GOTO READ
BTFSS IR
GOTO $-1
;====== READ ADDRESS 5 BIT ===========
; READ MSB FIRST
READ: MOVLW 5
MOVWF TEMP ; LOOP COUNTER
CLRF ADDR
READ1: CALL DELAY1252
BTFSS IR
BCF STATUS,C
BTFSC IR
BSF STATUS,C
RLF ADDR,F ; SHIFT LEFT ADDRESS
BTFSS IR
GOTO $+4
BTFSC IR ; WAIT LOW
GOTO $-1
GOTO $+3
BTFSS IR
GOTO $-1
DECFSZ TEMP,F
GOTO READ1
;====== READ COMMAND 6 BIT ===========
; READ MSB FIRST
MOVLW 6
CLRF CMD
CMD1: CALL DELAY1252
BTFSS IR
BCF STATUS,C
BTFSC IR
BSF STATUS,C
RLF CMD,F ; SHIFT LEFT COMMAND
BTFSS IR
GOTO $+4
BTFSC IR
GOTO $-1
GOTO $+3
BTFSS IR
GOTO $-1
DECFSZ TEMP,F
GOTO CMD1
MOVLW 0X3F ; 0011 1111
ANDWF CMD,F
MOVLW 0X1F ; 0001 1111
ANDWF ADDR,F
BCF STATUS,C ; C=0 NO ERROR
RETURN
ERR1: BSF STATUS,C ; C=1 HAVE ERROR
RETURN
; DEBOUNCE SWITCH
; DELAY 15 mS
DEBOUNCE:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
DEL_1: MOVLW .20
MOVWF CNT2 ; 1
DEL_2: CLRF CNT3 ; 1
DEL_3: DECFSZ CNT3,F ; 1/2
GOTO DEL_3 ; 2
DECFSZ CNT2,F ; 1/2
GOTO DEL_2 ; 2
DECFSZ CNT1,F ; 1/2
GOTO DEL_1 ; 2
RETLW 0 ; 2
; DELAY 1.252mS
DELAY1252:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
REP_1: MOVLW .5
MOVWF CNT2 ; 1
REP_2: MOVLW .81
MOVWF CNT3 ; 1
REP_3: DECFSZ CNT3,F ; 1/2
GOTO REP_3 ; 2
DECFSZ CNT2,F ; 1/2
GOTO REP_2 ; 2
DECFSZ CNT1,F ; 1/2
GOTO REP_1 ; 2
GOTO $+1
GOTO $+1
GOTO $+1
GOTO $+1
RETURN ; 2
DELAY3500:
MOVLW .1 ; 1
MOVWF CNT1 ; 1
MOVLW .23
MOVWF CNT2 ; 1
MOVLW .50
MOVWF CNT3
DECFSZ CNT3,F ; 1/2
GOTO $-1 ; 2
DECFSZ CNT2,F ; 1/2
GOTO $-5 ; 2
DECFSZ CNT1,F ; 1/2
GOTO $-9 ; 2
RETLW 0 ; 2
END
