SPI code example needed for PIC microcontroller?
elrayes
Full Member level 5
Full Member level 5
Egypt/Canada
pic spi example
Hi all
I need an example code for SPI interface for PIC microcontroller using C18 compiler, if you have a code working please post it, i don't need it for college project but i'm facing some problems with SPI interface and need a reference code to follow.
Thanks in advance
spi code for pic
Actually, I have the same question.
Specifically, I have read through the examples given, and I was wondering if there is common syntax for the C18 compiler for the following:
1) SPI read(char)
2) SPI write(char)
I ask because I see several commands in the postings, but I am unsure if they are standard, or written in code not shown there. I just need to send bytes of data to an external device using SPI interface.
Does anyone know of an API which has commands useful to micro-controllers using the C18 compiler?
I just need some simple commands, I can initialize the registers and SPI mode myself from the PIC datasheet.
Thanks in advance
