how to decide vco gain (Kvco) in your PLL?
eejli
Full Member level 1
vco gain
I am wandering how to decide Kvco in the beginning of the design of your pll?
It seems for me making Kvco from 1GHz/v to 100MHz/v does not make big difference since I always can find a loop filter to stabilize the loop.
Is there other conditions that can bound the Kvco?
Thanks.
vco kvco
What is your required step size ?
A VCO at 1GHz per Volt sounds strange, unless you are operating at 60GHz.
Shouldn't you design or find a VCO that meets your requirements (2nd Har,
Phase Noise, Stability, Temp Stability...) Then see what it's Kvco is and move
forward with the design ?
But I'm no expert, good luck
pll vco gain
I think your VCO circuit will decide the Kvco, and the loop filter size will also decide your Kvco.
1. Even if you can use any lopp filter size in your simulation, the filter size will be limited by your layout requirements.
2. Even if you can use any Kvco value, but it does not mean you can make the VCO act like it. So... I'm thinking you have to design a simple VCO, and you have to figure out the a rough estimate of Kvco.
These are what I am thinking... It might be wrong. :)
    eejli
kvco vco
Practically speaking, you want the lowest KVCO you can get and still tune over the desired frequency band.
For instance, it you have a 3 volt power supply, and you need to tune from 2 to 2.3 GHz, you need more than 100 MHz per volt for the vtune range available to cover the entire band.
If you made the KVCO much bigger than that, lets say 1000 MHz per volt, you would not gain anything by it, and the VCO would be much more susceptable to picking up stray noise.
Reactions: khungbopro
    eejli
    khungbopro
vco tuning range decide
Kvco is only on of some other factors forming the dc loop gain (which is the most important parameter as it influences stability and determines all relevant parametrs).
Therefore, I think choose an appropriate Kvco as available and correct it - if necessary - by tuning other gain parameters of the loop.
    eejli
pll loop filter design loop gain vco
dc loop gain is inf and KVCO can vary by more than 100% for ring VCOs over PVT and output frequency. It is a poorly controlled parameter and the design has to work with that. KVCO has to be made as low as possible without affecting the tuning range requirement to reduce output spurs due to the loop and the supply.
    eejli
vco gain factor for a frequency
KVCO ideally should be low because the power supply sensitivity of the VCO is lower. Hence your PLL detereministic jitter is lower as well. But on the other side, a high KVCO will also give you a better loop bandwidth which eliminates any lower frequency noise on the VCO. However, with respect to PVT variation being in the high KVCO range is not safe because you cannot really get good numbers with respect to the typical conditions. Faster, low temp corners will give exceeding high gains and slower, high temp corners could give horrible gains. This will effect the stability of the PLL over PVT.
But ideally have a low VCO gain because any small changes in the VCO control voltage also will not change the frequency output of the VCO.
Reactions: kumite
    eejli
    kumite
kvco simulation frequency
thank you guys.
Yes I agree that Kvco should be small for spur performance.
If Kvco is defined, then the charge pump current will be defined by the loop bandwidth assuming the divider ration is fixed and the loop cap is 100 pF for layout size reason. Am I right?
Thanks.
