Data transfer between 2 pic microcontrollers using SPI
gravi
Full Member level 2
Full Member level 2
Hyderabad, India
spi pic
I am trying to transfer data between 2 pic micro controllers Microchip PIC18lf8722 and PIClf2525 in which PIC18lf8722 acts as Master and PIClf2525 as Slave. so we have configured them as master and slave and sent some data to slave but data was not received in slave. can any one help me to complete this data transfer.
Thanking you,
Ravi Kumar.
pic to pic spi
what are the hardware connections
please send the circuit diagram
and did you ground the SS pin at slave side
spi pic to pic
try sending same byte twice because its a type of problem i faced in a circuit where we have to move the data twice so on first the byte will stored in the buffer and the previous ( for first time the garbage) will be transfered ans secondly the data will be transfered
I am not so sure whether it will work for you or not but it works for me
spi between microcontroller
can you please tell us the problem so the next person to read this will not repeat the same
pic microcontroller spi
hi,
I have used MCC18 compiler library specified spi functions and any way i will shortly post my code and schematic.
pic spi slave
I have attached my circuit which i have used, Slave select is controlled by master before starting my communication. This is my master and slave spi initiallisations
SPI Initialization with respect to Master (Pic 18F8722)
void InitSPI_Master(void)
TRISDbits.TRISD6 = 0; // Define clock pin as output
TRISDbits.TRISD5 = 1; // Define SDI as Input
TRISDbits.TRISD4 = 0; // Define SDO as Output
TRISDbits.TRISD7 = 0; // Define chip select as output
SSP2STATbits.SMP = 0; // Sampled at the Middle
SSP2STATbits.CKE = 1; // Data Transmitted on Falling Edge
SSP2CON1 = 0x22; /* Configures SDo, SDI,SCK and SS pins as serial port pins. Clock idle state Low and FOSC/64 */
INTCONbits.INT0IE = 0; // INT0 External Interrupt Disable bit
INTCONbits.INT0IF = 0;
INTCON2bits.RBPU =1 ; // Disable Pullups
INTCON2bits.INTEDG0 =1; // Interrupt on Rising Edge
SPI Initialization with respect to Slave (Pic 18F2525)
void InitSPI_S(void)
TRISCbits.TRISC5 = 0; // Define SDO pin as output
TRISCbits.TRISC4 = 1; // Define SDI as Input
TRISCbits.TRISC3 = 1; // Define SCK as Input
TRISAbits.TRISA5 = 1; // Define chip select as Input
SSPSTATbits.SMP = 0; // Cleared in Slave Mode
SSPSTATbits.CKE = 1; // Data Transmitted on Falling Edge
SSPCON1 = 0x24; /* Configures SDo, SDI,SCK and SS pins as serial port pins. Slave mode and SS controlled */
spi between pic
Hi all!
I have the same problem too.
In my project,dsPIC33F is the Master and PIC18F4550 is the Slave.
I use the oscilloscope to make sure that Master can transmit data correctly.
But the Slave can't recieve data and goto the interrupt.
Then i write a simple timer1 interrupt code to test the interrupt.
My Timer1 still can not goto the interrupt sequence.
I paste the test code.
Plz help me!
#include <p18f4520.h>
#include <timers.h>
#pragma config OSC=HS, BOREN=OFF, BORV = 2, PWRT=ON, WDT=OFF, LVP=OFF
#define TMR1_VAL 65536-16384
void Init_TMR1(void);
void timer1_isr (void);
#pragma code high_vector=0x08
void high_interrupt (void)
_asm GOTO timer1_isr _endasm
#pragma code
#pragma interrupt timer1_isr
PIR1bits.TMR1IF = 0;
WriteTimer1(TMR1_VAL);
PORTD++;
void main (void) {
PORTD = 0x00;
TRISD = 0;
Init_TMR1();
RCONbits.IPEN = 1;
IPR1bits.TMR1IP = 1;
INTCONbits.GIEH = 1;
while (1);
void Init_TMR1 (void){
OpenTimer1( TIMER_INT_ON &
T1_16BIT_RW &
T1_SOURCE_EXT &
T1_PS_1_1 &
T1_OSC1EN_ON &
T1_SYNC_EXT_ON );
Hello,
I'm new to this forum, and I want to make a connection between a SPI PIC18F4520 and a PIC18F2520, and I can not get a correct result.
Have you an example of correct exchange?
Thank you in advance
