LRC meter software???
Borber
Advanced Member level 5
on third flor
radio.ru/measure/6873
I need software for LRC meter published in Elektor 4,5,6/1997. Can somebody upload?
lrc meter
here is the binary for the eprom
now the only missing part is the code for the programable logic!
/Kyndal
lcr meter schematic
how did you get on with software location as i am contenplating in building this unit
(elektor lcr meter 1997)
elektor lcr meter
as it ended up. i had to buy both the eeprom and gal/pal from Elektor..
I posted the Eeprom code, but i dont think the pal/gal code is avaible anywhere :(
i finished the LCR and it works REALLY good once calibrated..
But for starters i would recoment you to locate the dificoult parts..
Picoampere diodes. The DSP and The Codec..
as these are Obsolete and hard to get.
i used another type of diodes. but i dont remember which. Sry.
everything else is off the shelve..
godluck It is a really good piece of equipment!
/Kyndal
radio.ru/measure/4319
can i get the circuit diagram for that meter ?
fcl meter
i would really like to help you more. but the thing is, that all my electronics
related stuff, is packed away in crates back in denmark. and i am in florida..
But i do know that i got it from the elector CD's which are also avaible on P2P networks, kazyaa, edonkey etc..
this also includes PCB layout. BOM etc..
if you are planning on making the pcb yourselve. you better have very good equipment, it is relatively big, and relativly fine dublesided board.
and through hole plating is nessesary atleast for the DSP and Codec, as the sockets for these will
be verry hard to solder without..
/Kyndal
lcr meter schema
such a shame all of the main parts for this meter are obsolete...
does anyone know of an actual lcr meter like elektor one but with actual parts ?
regards.
lrc metre
many thanks... very nice piece of hard/software !!!
would be nice to download it here.. once translated to english !!!
best regards.
I used babelfish to translate but it is still not fully readable... !
fcl-meter
HI
is provided file in the archive name .spl belong to sprint layout is i am or how i can open the file
regards
Fragrance
lcr-2 meter ru
*.spl is probably schematics file of sPlan
elektor rlc meter
would be *** very nice *** for some member here who understand russian to translate this project to english...
especially the .asm file, with comments in russian that are not translatable with babelfish or others...
the spl file is for sprint layout
available at https://www.abacom-online.de/uk/html/sprint-layout.html
with a FREE reader software
also would be nice if someone could translate this spl file layout to a pdf !!!!
very nice lcr meter project I think
I hope it can be extended in range with others aop, extended in frequency by using external sinus source
well...hope some other members will like it too...
Added after 7 minutes:
picture of this nice project
rlc meter sound card
sprintlayout has .lay extension
here is spl
rlc meter software
yes you're right..
splan is also available at https://www.abacom-online.de/uk/html/splan.html
with also free reader
I wanted to say about the .lay file inside, the pcb artwork... can someone translate into pdf ?
the main thing, translate from russian the .asm file in the rar archive on the site...the other things are readable...:)
http.//pro-radio.ru.
this 93513.spl.GIF is not the project itself, it is "only" a capacitor (with esr ?) meter schematic. the actual schematic of the project is this file below
dspic lcr
and here is the asm file of the firmware to put in the pic
there are comments in russian I would really like to have in english...
nedd good help.. I can give points for that.
peaktech 2165
asm is translatable. Problem is cirillic encoding but it can be selected in IE if you open asm with it. Then you can use translator, sentence by sentence.
rlc meter
it's ok like that... I'm doing the translation and will post the result in a few days.
sound card rlc meter
Hire is all project: **broken link removed**
\hard\go_lrc_v1_0.spl - is the shematic Splan v6.0
\hard\go_lrc_v1_0.gif - the same sbematic in gif format
\soft\*.* software
Hire is pcb :**broken link removed**
Warning: The pcb is the test pcb with errors. Same wire makes additionally.
Sprint Layout v4.0
Sorry for my bat english.
