OP AMP based level shifter
tamil_yes
Junior Member level 1
op amp level shifter
i need +/-2V to 0/4V OP AMP based level shifter for my project
can any one help me...
level shifting op amp
Why use OP AMP as level shifter? It's HUGE compared to other level shifter!
level shifter op amp
i need 741 OPAMP based level shifter for my project
Added after 13 minutes:
friends help me....
in my college lab 741 only available by using that only i have to design
level shift opamp
tamil_yes,
Configure the op-amp was an inverting amplifier with two equal input resistors. Let the feedback resistor equal the value of the input resistor. Connect a -2V fixed voltage to one of the input resistors. Connect the variable input to the other input resistor. You now have an amplifier with a gain of -1 with an output offset voltage of +2V. When the input is +2V, the outut is 0. When the input is -2V, the output is +4V.
Regards,
Kral
Added after 4 minutes:
tamil_yes,
Friendly suggestion: This topic belongs in the "Elementary Electronics Questions" category.
Regards,
Kral
level shifter opamp
thaking u
but i need DC level shifter thats clamper cicuit
in that i will give +2V to -2V as input and i have to get 0V to +4V
some of my friends r telling that dont use capacitor in ur design it will create more problem
please help me
Added after 11 minutes:
hi kral
can u give ur words as circuit
i cannt follow u
please
level shift op amp
tamil_yes,
Sorry about the quality. I don't have a good schematic drawing application.
Regards,
Kral
    tamil_yes
op-amp level shifter
i am not getting output for this circuit
op amp level shift
y not u use clampers
op amp level shifting
xulfee
ya i need clamper circuit
i having this but i am not getting output
can any one help me
level shifting using opamp
that i was saying that u use clamper with out opamp,just use diode n capacitors
opamp-level-shifter
if i am giving load then i should connect with OPAMP otherwise it will not work
i have to give power disturbunce line as load
if i am just connecting with capacitor and diode then with out load it will work
