valchid
Hi guys, I want to make a power supply which provides 3 regulated voltage lines: 12V,5V and 3.3V from a 14.8V battery.Whats the best way to do this without dissipating too much energy.Thanks
The answer to this will also depend on how many Amps you wish to provide at each of these 3 voltages.. . . a power supply which provides 3 regulated voltage lines: 12V,5V and 3.3V from a 14.8V battery.Whats the best way to do this . . . .
you can also use lm317
LM317 would waste a lot of power, the situation becoming worse as the input voltage and output current increase.Whats the best way to do this without dissipating too much energy.
be aware that you will not always get 14v from your battery. a car battery still works at 11v
but your ldo at 12v output will not work if you only have 11v at input
a step-up-down controller will...
regards.
