IWATSU SS-7611 Oscilloscope Schematic Needed
lewinskys
Newbie
Newbie level 2
iwatsu ss-7611
Does anyone have A schematic or servicce manual for the Iwatsu SS-7611? Even in PDF format would be a good start.
Or even a longer shot, Anyone have one for parts they looking to get rid of?
iwatsu ss-7610
Fantastic thanks alot. I hope this provides me with the help I need to repair it.
I have dot on the screen if I press the "CENTER" button, but no on screen display.
ss-7611
The service manual is for models
IWATSU SS-7611
IWATSU SS-7610
IWATSU SS-7607
IWATSU SS-7606
Oscilloscopes.
I was searching this manual for long time for my IWATSU SS-7606.
Thank you very much for your kind contribution.
iwatsu oscilloscope
Oscilloscopes.
I was searching this manual for long time for my IWATSU SS-7610.
Added after 1 hours 16 minutes:
IWATSU SS-7610 Oscilloscope
LOW VOLTAGE POWER
IC1 DIC823651 IC,HIC B365N <---- Schematic
ss7606_07_10_11-ser-e.rar
Service manual POWER SUPPLY P.206
I am having the same problem with mine 7606. 12V supply for cooling fan stopped working and scope does not power up as used to. Only 4 LED one for each channel light up. Can you post what you have found wrong with yours?
Re: ss-7610
Yes, I have the Service amual.
I also searched this manual for a long time. Many thanks for your sharing.:grin:
Is it possible I can get ss-7606 user manual anywhere?
Re: ss-7610
Hi!,
I have Operation Manual of SS-7607 and SS-7611.
Can´t find the SS-7606.
SDumas
  • SS-7611_SS-7607_Operation.pdf
Re: ss-7610
Hi!,
SDumas
Oh my, I don't know to say, thank you, thank you, thank you! Although the model is different, the way of operation the ss-7606 is the same. Only ss-7606 is short of some function-keys (she has Delta T, 1/Delta T and Delta V only) . Any way, thanks a lot! :grin:
Hi, I have a SS-7711 that the power supply has gone whit a numbers of cap that has leaked.. After change a number of caps and switch transistor, I discover that the IC1 "B365N" is not ok, a diode and transistor is shorted on the board, is there a schematic on this board? Have trouble to find the diode part number, it's marked with S4 80.
Sorry ,but you need to be more accurate on this you asked.
1-SS-7711 -I don´t know this model ,your mistake ?
2-If this is SS-7611 model ,you have the service manual ,see in the "roymg" post ,the second one.
3-you have the schematic of power supply in page 206 of this service manual.
4-After all this you can ask us to help you.
5-sorry for my (bad) English :cry:
Regards
SDumas
Sorry it's the SS-7611!
Have the sm and the schematic on page 206 only show the pins on the IC1, no components..
