phaedrus
Member level 4
high-side current measurement
Hello ,
Can anyone suggest how I can measure the current using a shunt resistor ( 1E,300mA with a potential of 30VDC).
A 3 OpAmp differential circuit using OP07 was what I had designed, but it needs the one of the inputs connected to ground which will obviously not work in this case. I need to amplify by a gain of 10 and feed it to an ADC.
As an alternative if someone can suggest some current sensing ICs commonly available in India,it would be helpful.
Hello ,
