13.56MHz Antenna Q factor - what is good value?
rvargo
Newbie level 6
Newbie level 6
13.56MHz Antenna Q
Hi, I am looking into 13.56MHz antennas to use for ISO 14443 and/or ISO 15693 applications. I've developed prototypes in the lab that are working, but I have a confusion on the 'Q'. The antenna I'm using is a loop antenna, and I match it by using a couple of capacitors. All of the sources I've read have said to set the Q of the antenna by using a parallel resistor, and there are plenty of equations to do this.
My question is: what is a good Q for those two standards? From what I've read, a higher Q will give longer read distances (can anyone explain that?), but also obviously a lower bandwidth. I'm just wondering if anyone has experience designing these antennas and can offer some insight into what I should set the Q at.
Thanks!
13.56MHz Antenna Q
Bandwith respectively intended data rate is the criterion to set up the antenna Q
The relation of Q and range is in conjunction with transmitter power. A higher Q means higher field strength with same
input power. But all RFID standards specify also a maximum field strength at the tag. So there's no use in increasing the field
strength above a certain value depending on the loop size and the respective RFID standard. For 14443, safe operation
directly at the loop should be possible. For 15693, you possibly can specify a minimum operation distance, allowing a
higher operation range. Check the specifications for details.
13.56MHz Antenna Q
i could give u an simplified answer.
the loop antenna is seen by a circuit as an inductor, thats why you match it with capacitors.
when u do that it becomes a parallel resonant circuit which is mainly described by its Q.
the Q in definition is the central frequency devided by the 3 db bandwith.
so the wigher the Q the lower is the bandwidth
and the wigher is the power transmitted to the load at resonance which is the central frequency.
so that's why it offers a longer read distance since power transfered is larger.
so in ur design u must choose the Q as large as possible as long it supports the bandwidth that the system must offer. this way you get max distance at a certain bandwidth.
13.56MHz Antenna Q
A typical transponder IC has Rload=20Kohm, with L=5.5uH, Rdc=3.5 Ohm >> with an N=1 winding on 1cm2 you can have a readdistance of 40-70 cm; depend of right tuned systems...
You must check, that with a bandwidth of ca. 1.5MHz on your needed distance the transponder min 2V becoms_this is the reason of compromiss between Rload(Q) readingsdistance & coil data...
K.
