add image is never at all easy in this forum once i add and upload and back to click on the quick post it is never happen ....
here i add i think
here i add i think
when i start analysing the circuit :
over voltage protection
r2 and r9 are forming a voltage divier which divide down the 280vdc at the secondery
side to safe lever and fed to the compartor via r39 which if raise to high level compartot will produce 5 volt at its output at pin 12 to pin "4" of the tl494 which will let this ic shutdown the inverter
high battery voltage is done by the zener zd15
low volltage is done by r4 r19 r22 voltage divider and a high logic out pin at pin 7
to pin4 tl494 and thus shut down
high temp sensor is done by ct1 ntc which will kick in p1 pnp transistor into operation if
tempertaure is high which will in its turn send 12 volt pulse to pin 10 of the comparator
which will int turn turn the n4 npn transistor which at last operate the fan
cant see any over current protection...
