Nils227
Junior Member level 2
What do you recommend at best for a DC-DC converter, bucking down an input voltage of 12VDC to 1VDC, noise-freely, with low EMI as possible?
I have been encountered with the ADP2303 but its working principle relies on a switching mechanism, and therefore can induce EMI.
The LM1117-n-7107 on the other hand heats up massively, despite that is possesses lower EMI than the ADP2303.
The destination is: the DC-DC converter should empower four magnetic sensors: TMR2309 effectively while inducing no EMI (in order to have the most accurate ADC readings out of it).
Do you have any suggestion? Perhaps with the relevent circuitry?
Thank you
Thank you
