+12V source switching (lowest part count, lowest cost)
Jester
Full Member level 6
Full Member level 6
I have done this a few times and the end solution never looks elegant.
I need to switch (control) a 500ma, +12V source ( with 5V logic). The switch must Source not sink.
Please show me your elegant solutions.
Here is a 4 component $0.40 solution
Well you are using P channel Mosfet that will not work as I can see. Use NPN BD 139 Transister.
what is the issue than ? yo uonly need to choose the right component rating, your circuit work perfectly
Yes it works, but can it be done with less than 4 components?
or
with less expensive components
or
both
Here is a 1 part SOT-363 165 mOhm $0.09 High Side 1A switch with extra parts for slew rate control. +/- 1.1A
Ding Ding Ding Ding Ding Ding ...... we have a winner
1/2 the parts in a small package for cheap:)
The +12V output will be connected to the load by the end user (ESD what's ESD?). Any suggestions for protection?
Thank you SunnySkyguy :)
Depending on some secondary values / concerns, a 5V
reed relay can be a nice simple and fairly reliable option.
Not as high a cycle reliability, but more resilient to some
overstress conditions (and providing isolation between
control and load, if that kind of thing matters).
Electro-Static-Discharge = ESD . This part has protection with intrinsic diodes.
This is a half bridge (complementary) emitter follower. THis is equivalent to SPDT between V+ and gnd but with Vce-saturation voltage drops and use where low impedance is but voltage drop is not as important.
I guess you did not catch my dry humor about ESD, I have had very limited success persuading most end users to take any ESD precautions with electronic equipment.
If low side switching is possible, then a single n ch mosfet with low vgth will do.
Klaus
