12v relay for momentary push button from ebay
d0rg
Newbie level 2
Newbie level 2
I have been unable to find an existing thread on this topic but sorry if it was me being blind...
I am looking for a relay switch or prebuilt circuit available on eBay which can be used to act as a switch in a circuit. I want to operate the relay using a momentary push button. So when I push the button the on/off state of the relay is toggled. Example: I push the button once and the relay changes from open to closed and if I push it again the relay changes from closed to open. I want the solution to run off a 12v DC power source
Does anyone know of a solution which can be found on eBay?
Cheers,
Serge
What you are looking for is a bistable, or latching relay.
Here's one designed with external components **broken link removed**
Or, a bistable relay with 2 coils **broken link removed**
Regards.
Thank you so much for the help in finding the right relay module :)
