John Livermore
Hi I'm new to the board and in need of some help. Im an amature astrophotographer and dealing with 12v and 120v power sources. I need to keep my equipment using 12v's an not rely on a 12v to `120v converters these was battery life which I need the most. The equipment I am questioning is fairly easy but my knowledge is none. I need to power my usb hub and DSLR using a 12v power. I primarily use deep cycle batteries and I've posted this on astro forums but no one seems to give a hoot so no replies. Hopefully someone here can take a min or two to help me out. First is the slr I have been using a regular 120v dummy power to keep the slr going because external batteries are a pain to have to keep up with and in a middle of a shot the battery dies I lose time so this needs to change. The converter I need is a 12v to 7.4 2A. I've looked at several but I really have no idea of what to buy. I need to keep this inexpensive and simple to put together.
The other source is my USB hub. The hub is 5v - 3-3.5a. I'm only guessing that a 3A will surfice correct. What are my options and perferably placing these in a simple project box either plastic or aluminum will be fine. I'm not looking for nothing fancy just something simple and easy to maintain. I hope you can help because I've ran out of options
