[SOLVED] 12V power source without any IC.
vmerter
Newbie level 1
Newbie level 1
Hi All,
I'm new to analog design. I need to design an 12V DC minimum 1 amp power source that takes input from 220V AC without using any ic component. I'm familiar with the transforming and rectifying. My only problem is I don't know how to design a steady voltage regulator. I'v looked up online but all of the designs uses ic components. Any research source and/or design examples will be appreciated.
Thanks in advance.
I'm (barely) curious why you "need" to use inferior
technology. If I had to guess, I'd guess this is a school
project and somebody else gets to set the boundaries
and criticize the BOM.
Your easiest regulator will be a zener + (N) forward diode
stack, followed by a Darlington NPN pair. You can find
zeners in pretty fine-binned breakdown voltages. The
tempco of a zener plus single forward diode is sorta-flat.
You'd add a couple of diodes up to compensate the couple
of diodes down, that the Darlington will impose. Your zener
stack pilot current must include the Darlington base current
at max output.
The linear supply will get way hot, so plan on at least a
big finned heat sink able to throw (VINmax-12V)*1A worth
of power. Maybe a fan too.
If you want good ideas for old timey analog designs, try
the discretes databooks and applications volumes from
RCA and Motorola semiconductor companies. You should
be able to find these on archive.org. I remember seeing
stuff like full designs (schematics and parts lists) for
>100W Class AB audio amplifiers to demo their matched
power bipolars and so on.
You could go further (if the regulation requirements laid
down by "whoever" demand it) and instead of an open
loop reference stack and follower, add a poor-boy discrete
error amplifier (op amp, made of discretes). This would
help load rejection and temperature stability big time as
reference stack Vf, and power NPN Vbe, are going to
drift apart with applied load. You ought to be able to
make a 4-6 transistor op amp, its offset voltage, speed,
gain are liable to be inferior to ICs but still better than
not trying at all.
