Tuppe
Member level 2
Hello,
I have a problem with 12V output from MOSFET to external device.
I need to have 12V output from my MCU, that is used as a signal to switch on a external device. The signal will be grounded within the external device(mutual GND)
The problem is, that I cannot find any circuit online that is used for this. Every circuit grounds the MOSFET and supplies 12V through it.
I cannot ground the MOSFET, because the voltage is going through the external device to GND. I got 12V on both Drain and Source.
My circuit works fully if I bypass the mosfet with a jumper, but I cannot electrically switch it ON, possibly due that I cannot ground it without creating 12V short to GND.
How can I make MOSFET to apply 12V to open lead? IS it possible? Do I really need a relay? I might have a brainfart here, but I seem unable to find solution.
Thanks!
Thanks!
