raffy0991
Newbie level 5
Hi Guys,
I am making a LED driver circuit for a 12 V LED array 5 digit 7 segment display Common Cathode. My input is from an Arduino which is 5v. So I need to create a LED driver and I have some ideas like creating a darlington pair and also the ULN2803A. However, I have only basic idea on electronics especially in transistors and IC and stuff. I need your help here is my initial simulation from Proteus but it does not turn on the LED. I used 2n2222 (NPN) and 2n5401 (PNP) since these are the only available transistors I have and I have plenty of these. Please check if I have done wrong on this circuit. I am also planning to use ULN2803A but I still have no Idea yet how to use it on a common cathode display with 12v power supply and input of 5v. Is it possible?
Hopefully you could help me guys.
Thank you
Thank you
