Yes actually it is a power supply for a Microcontroller....12V/13V switching power supply......I guess I should have posted in the other FORUM!! Thanks again guys!
I have though about making a power supply (Variable), switch for either 12V or 13V (some chips need 12V!)........The LM317.bmp LM317 structure, the one I have designed is in the pdf....Could you please help me with your experiance whether or not what I have designed will work...
THanks in advance!
(PS: I used the voltage calculator on LM317 Voltage Calculator - Electric Circuit)
PS: the '+13/+12' pin will be the output based on position of the switch PWR.
I have not built the design yet, but thank you for everything........one more thing.....what do they call a course where you learn how to make stuff out of metal...(you know, like small boxes, frames.....out of metal or even carbon fiber, etc)....and I have been working with Orcad to try and simulate some circuits...its a pain to learn it....anyone know any good books/tutorials.........
Thanks in Advance
