Santa
Member level 4
oxford 128gb limit
I encountered an infamous limit of 128GB with hard disk drives
mounted in external USB2 or IEEE1394 (Firewire) enclosures.
My first impression is that stupidity must be a self-sustaining
high priority process. After a 32MB, 300MB, 2GB, 8GB limit we now
have a launch for a 128GB limit in PCs. Does anybody still beleive
this can be just fortuitous? Some new enclosures are able to go
beyond this and this renders the "old" ones obsolete and the
new ones attractive. :2gunfire:
Now, to be more constructive than the inventors of that feature,
I would like to understand exactly from where this comes.
Let me however kill the first wrong and well distributed idea.
While it is true that W2K or other OSes must have their 48-bit
LBA support enabled to go beyond 128GB, the limit I am talking
about does NOT come from the OS. The same 160GB IDE disk
connected on an internal IDE adapter is detected as 160GB while
it is truncated at 128GB when installed on an USB/IDE convertor
plugged in the same system.
Some people say that only ATA-6 enabled IDE controllers are capable
of 48-bit LBA support and that, since many of the USB/IEEE1394-IDE
do not support ATA-133 work as LBA limited hence 128GB limited
devices. So it would be a limit of the command set of non-ATA6 drives.
Other say that this is purely a limit in the register size of the convertor
chips.
Anybody has got the light of Galadriel to make things clearer
in this darkness? :idea:
Thanks.
chips.
Thanks.
