Problem with using Ocean script to calculate power of inverter
achlebin
Newbie level 1
Newbie level 1
I am starting using Ocean Script to calculate power (for start) of inverter. I have made testbench and prepared simulation in Analog Environment than generated script with save script. I have started script with command load "oceanScript.ocn" and it is working but the results are different then those from simulator run "traditionally" both current and voltage waves looks the same but power calculation made by multiplying current and voltage is totally different. What can cause this and how to fix this.
