12 volts sealed battery charging circuit designing with constant voltage & current
rajaram04
Advanced Member level 3
earth
Hello
Given standby use : 13.5v - 13.8v
for a 12v sealed battery is there
A single or many chains of LED etc ll act as load further for hours
So how to make a charging circuit which can deliver charge with constant voltage & constant current supply ???
Re: 12 volts sealed battery charging circuit designing with constant voltage & curren
measure the voltage and current directely at the battery and you are safe.
Klaus
All the details of your many personal messages to me about this project are missing in this thread.
Before, you said occasional use so I selected the standby voltage. Now you say the load will be for hours which is not standby so the charging voltage for frequent use should be used.
Before, I discussed using an LM317 as a current regulator followed by another LM317 as a voltage regulator. You said you had a certain transformer.
We did not discuss charging the battery and powering the load at the same time.
Klaus
no actually i hv to deal with provided powerline for battery . .
means the power source for charging must have a constant voltage & current source
No its just for say 6 hrs or 8 hrs n so on & rest is on standby so forget the load part as its a part in absence of power supply
just i wrote the load details so as to start the thread as per advice
We need only concentrate on charger part as we discussed for 4v battery . .
please proceed sir :)
If you measure voltage and current then you have all information for a constant I constant U charging.
Just keep charging current constant as long as voltage is below 13.7V then switch over to constant voltage charging.
Klaus
o i see , so is there any design which we could implant in our system for auto switching as you said ?
I looked in Google and found many lead-acid battery charger circuits the same. They use an LM317 voltage regulator IC and a transistor that senses the current and it limits the current.
But I cannot remember the recommended charging current of your battery so I cannot calculate the current sensing resistor value.
ok let me reqrite the details laballed over the battery
its 12v 7.5Ah
constant voltage charge
voltage regulation
cycle use : 14.4v - 15v
maximum charging current : 2.25v
Too sir as the diagram talks about a 15v transformer , what if i apply a 18v in place ?
If you use an 18V transformer then the LM317 will get hotter and will need a larger heatsink.
We cannot calculate the charging current without knowing the maximum allowed continuous current from your 18V transformer.
& what if we convert 18v to 15v via LM317 before applying to our main circuit ?
what disturbances ll happen there ?
& my transformer is 18v 500mA
The little 18V/0.5A transformer has a maximum output of only 9VA. Its peak voltage is 25.5V so the maximum current you can charge with is 9VA/25.5V= 353mA.
If your 7.5Ah battery is dead then it will take 7.5/0.353= 21.2 hours to be fully charged. I cannot remember its standby maximum charging current.
When loaded, the 25.5V peak is reduced to 23.5V by the bridge rectifier then ripple reduces it further to 23V.
With such a low current the 13.7V LM317 will heat with only (23V - about 12V) x 353mA= 3.9W which is not much. A fairly small heatsink can be used. An additional 15V regulator is not needed.
wowww if it is 353mA then its ok for experiment i guess . .
& ya i ve that heat sink for the purpose
so . . . finally should i apply this 18v directly to the main circuit ?
may i proceed sir ?
What is the maximum standby current rating of your battery? If it is less than the charger current then the battery must be disconnected from the charger when it is fully charged and you will need a circuit to detect that it is fully charged.
Are you using an LM317 in a TO220 package?
If you use thermal paste and if your heatsink is rated for cooling 3.9W then an input of 18VAC to a bridge rectifier and large main filter capacitor is fine.
Did you calculate the value of the main filter capacitor?
Did you calculate the value and power rating of the current sensing resistor?
standby current rate of battery is not laballed so please tell any method to find it out ?
Though i ve encountered so many cincuits but in my case how could i design the detector circuit to know about the battery is fully charged ?
yeah i am using only TO220 packacge
I hv heat sink paste but what should be the area of heat sink plate so as to rate it for 3.9W ???? No idea,please help
Its bridge rectifier i am applying & filter capacitor value is 1000uF
Whats the procedure to calculate value and power rating of the current sensing resistor ?
sample indicator diagram for the very simple indicaton of low charge full charge & over charge . . here a 13v zener is mentioned
I ve got it here on this site only
but now hv to make the over charge indication for 13.7v
You can learn about batteries in Google or at www.batteryuniversity.com . It says the recommended continuous trickle charging current and how to measure a full charge (reduction in charging current?) for a few types of batteries.
yeah i am using only TO220 package
We use an inexpensive manufactured heatsink with fins that has a W rating.
That is fine for 350mA or less.
You look at the datasheet for the transistor. It shows a graph of its typical Base-Emitter Voltage Vs Collector Current. You need the voltage when its collector current is low at about 1mA, at 25 degrees C.
Then you use Ohm's Law to calculate the resistor value and its power rating.
The Maximum power from your little transformer is 353mA when it will be very hot inside. Use 300mA to calculate the current sensing resistor to be safe.
