speedshop
Junior Member level 3
I'm looking to build a replacement ignition for my motorcycle. It has a capacitor discharge unit that is powered by a coil in the generator.
I want to use a DC to DC converter to charge the capacitor to 400 volts instead of the 110 volts it normally runs at. The capacitor in the standard unit has on it 4k4, which I guess is a 4.4uF item. The capacitor will be charged by the converter and the discharge controlled by a SCR whose gate gets its signal from the timing side (I'm using the signal from the standard generator for now - changing this is another project, I want to get the cap charging sorted first!)
I have had some success building a direct replacement for the standard ignition box powered by the coils in the generator. My unit runs fine using a 1uF capacitor, but the spark is noticeably weaker. I think I will opt for a pair of 1.5uf capacitors in parallel in the DC powered unit.
Question is can i buy off the shelf parts to build a converter (i don't want to get in to winding inductors)?
The power supply must be be stable and relaible, so must be well within its design spec and mustn't need fiddling or contanst messing about with to keep it running. Robust is components are good as they will be exposed to a high level of vibration.
Can I pot the unit without problems from heat?
Also the inverter should run from about 7 volts to 18 volts (if possible - if not as wide an input voltage as poss).
Any pointers or resources i can look at?
Thanks for your help
