smileykid2012
Newbie level 2
While designing and simulating a 12 bit R-2R ladder DAC using MOSFETs, during the transition from the bit combination 011111 111111 to 100000 000000, the analog output decreases..I have designed the op amp as a simple two stage op amp and the supply voltage used is ±1.65V.The switches in the ladder network have been replaced with MOSFETs.. When I simulated a 3 bit circuit, I got the exact output levels. As the number of bits increases, the gain error of the circuit increases..
Can anybody suggest some methods to solve this problem??
