Verilog Module instantiation in VHDL
sameem_shabbir
Full Member level 1
Pakistan
verilog instantiation
Hi all
I am a verilog user , I am facing problems in instantaiting verilog module into VHDL
Below is the instantiation which i did
CPU: Calc PORT MAP(
eof => eof,
blank => blank,
clk1x => clk,
r => r,
rmd => rmd,
mlpl => mlpl,
sqr => sqr,
quo => quo
But the compiler is giving syntax error
Undefined symbol 'Calc'.
Where as Calc.v is the verilog file which i am trying to instantiate
can any body help me how to correct this error
verilog module instantiation
COMPONENT Calc
PORT(
eof : IN std_logic;
blank : IN std_logic;
clk1x : IN std_logic;
r : IN std_logic_vector(2 downto 0);
rmd : OUT std_logic_vector(7 downto 0);
mlpl : OUT std_logic_vector(31 downto 0);
sqr : OUT std_logic_vector(31 downto 0);
quo : OUT std_logic_vector(31 downto 0)
END COMPONENT;
CPU: Calc PORT MAP(
eof => eof,
blank => blank,
clk1x => clk,
r => r,
rmd => rmd,
mlpl => mlpl,
sqr => sqr,
quo => quo
But if i go for components (as done above)
I get this much of errors:cry:
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 489. parse error, unexpected COMPONENT
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 492. parse error, unexpected IN
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 493. parse error, unexpected IN
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 494. parse error, unexpected IN
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 495. parse error, unexpected TOKOUT
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 496. parse error, unexpected TOKOUT
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 497. parse error, unexpected TOKOUT
ERROR:HDLParsers:164 - "F:/XESS/Programms/trial/Video Modification For corelation/video.vhd" Line 498. parse error, unexpected TOKOUT
instantiate verilog module in vhdl
have you defined the entity and architecture correctly & after component and signal declaration you have to start with begin for logic description
instantiate verilog in vhdl
Thnx for ur help
But i know very less about Vhdl
I am attaching both files (Problem >xs3_video> calc.v & video modified.vhd)
can you plz instantiate it for me :cry:
Plz
module instantiation in verilog
i Have seen the code mistake is that component declaration should be above begin just cut the component part and paste it above begin
