ASIC_intl
Banned
design compiler uniquify
Hi
I have two separate question as shown below.
1. I am using design compiler in Tcl mode for synthesis. When I am writing the file necessary for synthesis at the begining I an setting the search_path, link_library and target_library variables.
Then I am reading all the verilog files (netlists) by the read_verilog command. After that I am setting the current_design. Then I am writing the uniquify command. Is it important to write the uniquify command for synthesis.
2. After the uniquify command in the above file (as described in question No. 1) I am writing the link command. Is it important to write the link command while doing synthesis? Can I do the synthesis without the link command? The above file (as described in question No. 1) also contains other necessary commands for synthesis after the link command.
Thanks,
ASIC
Hi
Thanks,
ASIC
