SOLDERING IRON TEMPERATURE CONTROLLER
ziaulislam
Member level 4
Member level 4
soldering iron temperature
I am in need of mains (220V.45W) SOLDERING IRON TEMPERATURE CONTROLLER
Circuit Diagram ( I will Prefer SG3524 PWM cont I.C based Design with out complex
Ferrite Transformers) Discations on this topic also welcome.
Thanks !
soldering iron temperature control
No REPLY sad :cry::cry::cry::cry:
Any thing gays.??????????????
soldering iron temperature controller
In my opinion using the soldering iron directly to a 220V it's complicate and dangerous, more common is a 24V unit. Some ideas here:
soldering iron temp controller schematic
Thanks! mister_rf
I think last one is good for me
after down loading Data sheets I can modifie
for 220V Iron.
temp controller soldering
mister_rf I can't find SP602 in Local market. will you
suggest any replacement ?
I shell be very thankfull
solder iron temperature
You need to use an OA with low voltage up to 6V, rail-to-rail,
Initially was used MCP602
try to replace with other circuits. Check if the pinout is compatible, (you need only one OA circuit from multiple) or adjust according datasheets
LMV321, LMV358,
LT1366
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1155,C1001,C1158,P1489,D4286?
TS921
http://www.st.com/stonline/products/literature/ds/5560.pdf
LMC6442
MC33502
http://www.intusoft.com/onsemipdfs/mc33502.rev5.pdf
MC33202
http://www.intusoft.com/onsemipdfs/MC33201-D.pdf
soldering iron schematic
HI,
I was try this and i thing that is the best temp controller for 220V iron and for me.
replace lmv321
linoko ! Thanks for your reply
But 404 File Not Found: The File files-eboard/solder-reg_2_1030.rar does not
exist.
Pleas ! Reoupload
solder iron temperature control circuit lm358
mister_rf
I find LMV358 in the local market but it did not work properly. It also getting hot
after some time.
I use LM358 but change in the temperature range is to LOW.
Any other suggestion ?:|:|
Mr. linoko please upload gain.
ZIA
Please check your schematics. MCP601/LMV358 power supply is limited to 5.6V by a zenner diode.
MCP601 maximum current drawn is less than 1mA. There’s a 6k8 resistor to connect the output to UAA2016 input.
By the way, how do you have adapted this schematics for 220/230Vac power supply?
lmc6442
mister_rf
It is simple I will use MOC30 SERIES OPTO COUPLER in the out put of
UAA2016 .
solder iron temperature control schematic
Mr linoko !
Please upload again Your schematic file!
uaa2016 schematic
ziaulislam said:
mister_rf
UAA2016 .
OK
So how it's connected the 220Vac power supply to the circuit?
solder temp controller
Hi Friends,
I'm reuploading the file now
Success for all
Reactions: kkluci
    kkluci
uaa2016
mister_rf I will connected the 220Vac power
supply to the circuit . As shown in the Attachment
soldering iron temperature controller schematic
mister_rf Hi !
I think you suggest GOOD circuit.
Thanks !
