117-301 practice exam
zdrhykm
Newbie level 2
1. Which of the following is the correct syntax for including a schema file in slapd.conf?
A. include /usr/local/etc/openldap/schema/core.schema
B. allow /usr/local/etc/openldap/schema/core.schema
C. permit /usr/local/etc/openldap/schema/core.schema
D. add /usr/local/etc/openldap/schema/core.schema
Answer: A
2. Select the INCORRECT statement regarding the LDIF file format:
A. It must contains a "dn" line (or distinguished name), that indicates where the attributes listed in the following lines of the file must be added.
B. In the file, a blank line separates one entry from another one.
C. If the attribute contains binary data, some specific configurations must be made for this entry.
D. The LDIF file accepts any type of file encoding.
Answer: D
3. Which of the following describes correct LDAP service definitions? (Choose THREE correct answers.)
A. LDAP was developed as a lightweight alternative to DAP.
B. LDAPv6 is the latest stable version specified by RFCs.
C. LDAP follows the X.500 directory standard.
D. X.500 directories can run only over TCP/IP.
E. LDAP is optimized for searching information.
Answer: ACE
Test1pass Practice Exams for Lpi 117-301 are written to the highest standards of technical accuracy, using only certified subject matter experts and published authors for development.
