how to interface gsm modem to microcontroller via RS232?
sudu86
Newbie level 3
Newbie level 3
gsm microcontroller
hi guys,
i'm planning to interface microcontroller with a gsm modem which has RS232..
my main requirement is to bypass the usage of computer..
can i do it??
please help me out..
i want to take the output from the gsm modem and directly interpret it using a microcontroller
thanks
interfacing gsm modem to 8051
you can search a article from elektor electronics magazine (January 2003)
all details is given in to the article , and programming provided as well .
Reactions: jc maganye and guls
    V
    guls
    jc maganye
gsm module interface
what you need to know is to learn microcontroller serial communication. normally for simple interface with gsm module just used tx,rx and gnd...gud luck
gsm modem microcontroller
Do you have the datasheet of the GSM modem which contains the protocol to be followed?
gsm interface with microcontroller
it is ok , but i think it need initiation process . to configure it according to the your use.
gsm module microcontroller
normally gsm module come with data sheet and designer guide. this guide is important because it give you information about command for configure...
gsm interfacing with microcontroller
you get this article
gsm modem interfacing with microcontroller
Can u give me the details of the elektor electronics magazine (January 2003) ??
I know nothing about this
There are some modems' which support RS 232 transmission. You may be interested in this **broken link removed**.
i have this modem **broken link removed**, and i want to connect it to a easypic 4(wich has a pic16f877) board.I can communicate with the modem and send to it AT commands only if before i connect the modem to pc with the terminal and i DON"T close the connection, i just remove the serial cable from the pc and connect it to the board. it's certain that it's about the initialization of the connection between devices. how does hyperterminal do that? can anyone help me pls?
Pls, i need help. Can anyone help me what i should do to connect my siemens C55 phone to my PC using serial port DB9 and hyperterminal.
When ever i connect it using a max 232 data cable, either the phone goes off or it shows network search.
Pls i am desperate.
thx in advance
jerry2010.
