115V/230V synchronization signal for phase control
cyberblak
Full Member level 2
Full Member level 2
Canada
Does anyone know a good synchronization circuit for digital phase control of an AC motor?
The circuit needs to generate a pulse (or an edge) at each zero-crossing of the mains voltage, and it needs to be isolated.
I should add that I need a circuit that is less power-hungry than a simple resistor with an optoisolator (the resistor dissipates a lot of heat!)
Any idea?
Thanks,
cyberblak
Take a look at the circuit below ..
Part of it, build around H11L1 and Q1, is an example of an optically isolated zero-crossing circuit .. (The H11L1 can be replaced by any similar opto-coupler, D1-D4 should be 1N4004 or any other diodes rated for 400V) ..
Regards,
IanP
