orcad layout error code
buenos
Advanced Member level 3
Florida, USA
orcad error codes
hi
i want to convert my altium pcb files to allegro board files.
someone said i have to do it like this:
-save as protel ascii2.8
-import in orcad layout+ then save as orcad layout .max file
-convert max to brd
when i try to import in layout+, it starts, but then stops without any message. but if i open the generated log file, i find this:
Mon Dec 03 14:42:38 Loaded file G:\PROGRAM_FILES\CADENCE\PSD_15.1\TOOLS\LAYOUT_PLUS\DATA\PROTEL.TCH
Mon Dec 03 14:42:38 Error code 5226.074 (8)
whats the problem? how to check the error codes? how to fix it?
error code 5226.074
Pls check if you can extarct ASCI file from the board file.
orcad error code 5226.074
that was a protel 2.8 ASCII file.
the other problem is to solve the error codes meaning. that would help.
