convert receive USART data to control PIC ports
bbgil
Full Member level 2
Full Member level 2
lcd_cmd(130)
GUys, i want to convert received data from USART to control individual ports in PIC. i used the library functions in MikroC. the problem is how make the PIC read the individual data to compare them to the PIC char and then control their function. in this code, just simply turn on LED on porta bit 0 and bit1. really need to make this work. thanks in advance
unsigned short pos, i;
char lcdtext [41];
char *tc1 ="on";
char *tc2 ="ot";
void main (){
TRISA =0;
PORTA =0;
Usart_Init (9600);
Lcd_Init (&PORTB);
i=0;
while (1)
if(Usart_Data_Ready ())
lcdtext = Usart_Read ();
i++;
if (i==2)
i=0;
Lcd_Cmd (LCD_RETURN_HOME);
for (pos=0;pos<40;pos++ )
Lcd_Chr_CP (lcdtext[pos]);
if (lcdtext == tc1) portA.f0 = 1;
if (lcdtext == tc1) portA.f1 = 1;
if (pos==16) Lcd_Cmd (LCD_SECOND_ROW);
Usart_Write('Y');
Added after 1 hours 41 minutes:
i think i need to create a buffer register to contain all the receive data from USART then compare it to my text character. But how to do this in MikroC? need help
usart_data_ready +mikroc problem
Hi
What you are looking to do is depend on the data you send to PIC whether you are using a protocol to communicate with PIC or or sending a single byte command
If you are using a protocol you will need a circular buffer and a parser soft rotuine to handle data comming from PIC uart
If you are only using a command byte it is more easy to do the job
All the best
Bobi
    bbgil
avr usart receive 0x00
Bobcat,
thanks for the info. But how to do this. doing only byte commands and i tried putting a buffer but can't say i know exactly what i'm doing here. the LED 2 is blinking but i don't think its the carry way. hope u can direct me to a link or a sample to do this buffer and parsing. thanks
char lcdtext [41];
unsigned short lcd, buf ;
unsigned char buffer[]={0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00};
char *tc1 ="on";
char *tc2 ="ot";
void main (){
TRISA =0;
PORTA =0;
Usart_Init (9600);
Lcd_Init (&PORTB);
i=0;
while (1)
lcd = Usart_Read ();
i++;
buffer[buf]= lcd;
buf++;
if (buf == tc1) portA.f0 = 1;
else if (buf == tc2) portA.f1 = 1;
if (i==40)
i=0;
Usart_Write('t');
convert char to byte mikroc
First:
You need transmit and receive circular queues (buffers) that are interrupt driven, that is you use the char received interrupt to place it into the receive queue and the transmit char complete interrupt to send the next char from the transmit queue.
Second:
You can then use the main loop of your program to look for commands in the receive queue. If you are searching for text commands you can use the strcmp() or strncmp() string compare commands, pay attention to text case.
I switched to Atmel's AVR micros and haven't used PIC micros in a long time. I have never used MikroC, so I cannot help you with exact syntax. Have you tried looking for app notes on the MicroChip web site to find some examples? Good luck.
