DRC means Design Rule check(like width of metal,Distance b/w two wires etc)
DFM mean Design for manufacturing which means the issues related to Leakage power,Dynamic power
DRC - Design Rule Check
This is specified by the technology and foundrys all over the world give out these
rules for a particular technology. These rules have to be satisfied in any design (physically)
DFM - Design For Manufacturing
Its a pretty much new thing which has been there since the 90nm node. As yield and reliability became important factors, foundrys brought out the DFM, which is making designs reliable and yield high.
These are set of rules , i would say guidelines that cover over the DRC rules. These rules are optional but as we go down the deep submicron technologies, its highly important to follow these DFM rules in order to make sure the product is reliable and yield is maintained high.
Making a design with DRC rules has a high probability that the yield of the design is quite less...
Foundrys specifically recommend all the design companies to follow DFM rules wherever possible...Its all in the hands of the designer...The designer should keep DFM rules in mind when designing ...
