Explanation of the contamination delay
gck
Full Member level 3
Full Member level 3
Pls tell me, what id contamination delay.
Re: contamination delay
Hi gck,
This time is genrally used in Flops, it is the amount of time taken to make a change at the Q from the moment when the clock edge is applied. This is very important in estimating the hold time.
Thanks and Regards]
satyakumar
contamination delay
hi satyakumar,
will u pls put more light on this, if any doc is there pls upload.
Hey...
contamination delay is nothing but the minimum or the least amount of delay taken by the logic element...whereas critical path delay is the maximum delay taken by the logic element...of course it determines the Hold time in your design....
contamination delay
@satyakumar,
"it is the amount of time taken to make a change at the Q from the moment when the clock edge is applied "
IS IT "Tcq" OF THE fLIP FLOP THAT U ARE REFERRING TO ???
You need to understand that VALID inputs take time to appear as VALID outputs. This delay (or time) is nothing but the propagation delay.
But INVALID inputs take a finite time (or delay) too to appear as INVALID outputs. This is known as Contamination delay.
If you think it from transistor level point of view, think of the threshold voltage of the transistor. But if you are thinking from Digital point of view, think of the Noise Margin analysis.
Actually speaking you need the contamination delay only while designing circuits, else you can assume it zero in your timing analysis.
Cheers!!!
contamination delay
Very interrsting question. Please does anyboby have documentation on this subject to share it ?
Thanks.
I will try to make the diagrams and post them here, give me some time.
Contamination Delay:
Here is clear explaination of Contamination Delay
  • Timing.pdf
nice pdf...gives the transistor analysis of the sequential circuits and timing concepts..must read i may say
Thanks ram..
Very useful question and answers. thanks ,all
