how to simulate a loop antenna in HFSS
corncat
hfss loop antenna
I am wondering how to build and simulate a loop antenna which works beetween 0.9 GHz and 3 GHz in HFSS. It is urgent! Looking forward to your warm-hearted help! Anything related to the loop antenna will be great!
Thanks once again!
loop antenna hfss
(1) draw a airbox;
(2) draw loop;
(3) add lump port;
(4) setup the solver and simulate;
(6) obtain the S11 and farfield;
loop antenna hfss simulation
what kind of loop? patch on the substrate or a kind of rod?
Thanks once again!
    corncat
    V
ghz loop antenna
As for the kind of the loop, the simplest one will be great. I am just wanna figure out how to establish a loop antenna project in HFSS first. Then I will improve the design of the antenna. Thanks!
I am new to HFSS and i am also looking to simulate printed loop antenna for a large frequency range starting from 700MHz to 5GHz. and my antenna size will be 65*10*0.8mm^3.
so for me boundary should be :Radiation and excitation should be wave port is it correct? and i am totally new to HFSS so any video explaining the whole procedure would be great i tried a lot to search on youtube bt couldnt find any
hope to get a quick reply from you eminent guys
You have to draw a "air-box" (empty box), and this box hase to be set as Radiation Boundary
I think for a loop antenna a lumped port is more adequate.
You should use the forum search for HFSS tutorials, there are some.
