How to program a keypad to work as a mobile phone keypad using PIC?
yahootew3000
Junior Member level 3
Good day,
May i know how could i programming a keypad extractly like the mobile phone keypad using PIC? For instance, when we first press the 2 button, it is an 'a', second press is a 'b' den is 'c',finally is '2', then it repeat the routine. Same for other buttons. So, the 4x3 keypad can have output for 0-9 and a-z. Please kindly give me the code if anyone of you have it, or at least give me an idea how to program it. Thx in advance.
mobile matrix keypad
I write this program for AVR
if you whant I can give you ...
or I can give you some details but I never use PIC !!
program for keypad avr
ok...can you please give me..email : yahootew3000@hotmail.com
if possible,then you let me know the details..thx..
the code of keypad of mobile
ask your questions and I will answer them (if I can!)
do you whant my AVR programs source? whit C .
c code keypad mobile
yes..i want it...could you send to me?yahootew3000@hotmail.com or post it here...thx...the code is programmed in C language?
mobile phone keypad codes
ok
the source code + codevision code + proteus simulation file
but its not complate !!!
this keys are working : 1-2-3-4-5-6-7-8-9
and other 3 keys dont work (0 - * - # )
its a sample you can fix the other keys errors
it this helps you....then push the HELP m button please :oops: :wink:
  • mobile_key_board_1470.rar
Reactions: zaidpirwani
    yahootew3000
    V
    zaidpirwani
external mobile phone keypad
amiralib said:
ok
even it does not help much...i thought it is an mobile phone type keypad...anyway, i just give you a helped click..thx
mobole phone
amiralib said:
press "2" it types "a" ...again "b"...."c"...."2"
I think you need this!
oh..is it?i thought you mentioned that 0-9 keypad...then, i try review it...thx a lot..
mobile phone keypad how to use
I am designing an advertising stand which will use a mobile phone (with a program running on it) for input processing. To protect it from vandalism and theft, the phone will be hidden within the advertising stand. The users will use a standard numeric keypad for data-entry.
Question:
Can the phone recognize key-strokes on the external keypad as digits out-of-the box or will I have to add some code to the mobile phone application so that the phone understands which key on the keypad has been pressed?
PS: The keypad will be connected to the phone either through USB-cable or through Bluetooth.
Any help would be greatly appreciated!
