How to generate pure sine wave from PIC micros? !!!
hassan1980
Full Member level 4
Full Member level 4
pic sine wave generator
Did anyone before deal with such thing?
pic sine wave
I haven't dealt with PIC but in AVR I have used Look-up table with precalculated sine-wave data. Just read and send out through DAC.
With PIC do the same:
Save one period sine-wave to like 256x8 size table in Program memory or another. then using DDS algorithm or simple read one by one end output to port where DAC is connected. DAC can be simple R/2R resistor ladder.
Here is what I've found for PIC: PIC signal generator
pic sine
You achieve it by use of built-in PWM circuit, reading a table.
Operating at frequencies above 60Hz waves, PIC's uC's have not enough speed. It should be better choice a processor containning a float point ALU, like a DSP.
At PIC, I Created a .XLS file to adjust maximum duty-cicle, and then filled that values at a static table.
Bellow, a piece of code, used at an UPS, using CCS C compiler :
const unsigned int8 Duty0  [] = {7,15,23,31,38,46,53,61,68,75,82,88,95,101,107,113,118,123,128,133,137,141,144,147,150,153,155,156,158,159,159,160};  // 126 Vac@24Vdc
const unsigned int8 Duty1  [] = {7,15,23,30,38,45,52,60,67,74,80,87,93,99,105,111,116,121,126,130,134,138,142,145,148,150,152,154,155,156,157,157};
const unsigned int8 Duty30 [] = {5,10,15,20,25,30,35,40,44,49,54,58,62,66,70,74,77,81,84,87,90,92,95,97,99,100,102,103,104,104,105,105};  // 117Vac@18Vdc
const unsigned int8 Duty31 [] = {5,10,15,20,25,30,35,39,44,49,53,57,61,65,69,73,77,80,83,86,89,91,94,96,97,99,100,102,102,103,103,104};
const unsigned int8 Duty32 [] = {5,10,15,20,24,29,34,39,43,48,52,57,61,65,69,72,76,79,82,85,88,90,92,95,96,98,99,100,101,102,102,102};
void CarregaPWM ( void )
   if ( direcao == CRESCENTE ) PWM_counter++    ;
      else                     PWM_counter--    ;
   switch ( PWM_counter )
      case 0  : NivelMinimo()   ;  set_pwm1_duty ( 0 )                 ; break ;
      case 1  :                    set_pwm1_duty ( Duty[PWM_counter] ) ; break ;
      case 2  :                    set_pwm1_duty ( Duty[PWM_counter] ) ; break ;
      case 29 :                    set_pwm1_duty ( Duty[PWM_counter] ) ; break ;
      case 30 :                    set_pwm1_duty ( Duty[PWM_counter] ) ; break ;
      case 31 : NivelMaximo()    ; set_pwm1_duty ( Duty[PWM_counter] ) ; break ;
void AvaliaBateria ( void )
   switch ( NivelBateriaAtualizado )
      case 0  : Duty[PWM_counter] = Duty0[PWM_counter]  ; Beep = CONTINUO     ; break ;
      case 1  : Duty[PWM_counter] = Duty1[PWM_counter]  ; Beep = CONTINUO     ; break ;
      case 31 : Duty[PWM_counter] = Duty31[PWM_counter] ; Beep = MUDO         ; break ;
      case 32 : Duty[PWM_counter] = Duty32[PWM_counter] ; Beep = MUDO         ; break ;
    hassan1980
pic sinewave
I made a sine-wave stand-alone inverter, and here a sine-wave constants:
const long sine_wave[32] = {81,162,241,318,392,462,527,588,642,691,733,768,795,
815,827,831,827,815,795,768,733,691,642,588,527,462,
392,318,241,162,81,0};
This is a only for one half of sine-wave.
Best regards
sine wave generator pic
Actually, I don't have any idea about C programming.
on the other hand I am using PIC Basic Pro language, can you help me?
