Looking for VHDL code for adder
vhdl code for full adder
Dear Sumant, there are countless types of adders, what kind do you want. pls specify. Nevertheless, I paste a fulladder code here
Kr,
avi
http://www.vlsiip.com
Library ieee;
Use ieee.std_logic_1164.all;
ENTITY fulladder IS
PORT( A,B,Cin : IN std_logic;
sum,Cout: OUT std_logic);
END ENTITY;
ARCHITECTURE functional OF fulladder IS
BEGIN
PROCESS(A,B,Cin)
BEGIN
If (Cin = '0' and A = '0' and B = '0' ) then
sum<= '0'; Cout <= '0';
elsif(Cin = '0' and A = '0' and B = '1') then
sum <= '1' ; Cout <= '0';
elsif(Cin = '0' and A = '1' and B = '0' ) then
elsif(Cin = '0' and A = '1' and B = '1' ) then
sum<= '0'; Cout <= '1';
elsif(Cin = '1' and A = '0' and B = '0' ) then
elsif(Cin = '1' and A = '0' and B = '1' ) then
elsif(Cin = '1' and A = '1' and B = '0' ) then
elsif(Cin = '1' and A = '1' and B = '1' ) then
sum <= '1' ; Cout <= '1';
else
sum <= 'X' ; Cout <= 'X';
end if;
END PROCESS;
END functional;
vhdl adder
U can also use the adder in the COREGEN if ur're using Xilinx
full adder vhdl code
Use VHDL's "+" operator.
vhdl full adder
this would be the simplest and the best implementation.
if u r using any synthesis tool it can infer the adder u want(not for FPGA though,only for ASIC)
vhdl code for adder
just use "+"! adder is widely used in designs, you cannot use adder module for it everywhere.
adder vhdl
hi friend ,,
i think u can use this code for full adder !!! its easy
library ieee;
use ieee.std_logic_1164.all;
entity full is
port ( a,b,c : in std_logic ;
sum , carry : out std_logic);
end full ;
architecture fulladder of full is
begin
sum <= a xor b xor c ;
carry <= (a and b) or ( b and c) or (c and a);
end fulladder ;
verilog code for adder
Please I need the verilog code(HDL) for Full Adder by using CMOS technology
