Lord Banshee
Junior Member level 2
orcad vhdl
OK well i wanted to test something like the following using SPICE simulation.
I have some VHDL which is just a PWM generator. I would like to add this VHDL in a A/D circuit in PSPICE and test it with some different value resistors and capacitors for a low-pass filter for the output... Basically to create a 1-bit DAC. But i have no idea how to do this at all.
I've tried to add a VHDL file, create part from it but when i try to simulate it tells me no pspice template U1 ignored, thus creates an open net for the resistor.
So does anyone have a how to to do this with OrCAD SPICE?
I am using Orcad CAPTURE CIS v 9 and/or 10 i think.
If this is the wrong forum for this kind of question please advise me to the correct one.
Thank You,
Chris
Thank You,
Chris
