T
treez
Hello,
We are supplying twenty 10W LED lighting fixtures from a 100VDC bus.........is it true that when we connect a fixture to the 100VDC bus, there will be such severe arcing between the metal contacts of the connector that the connector will not last more than a few months?
Can we alleviate the problem by using some kind of inrush protection , whereby the arcing current is limited by a resistor which gets switched out after the initial arc?
Does the attached schematic offer a solution?.....ie it gives us a chance to make the contacts when there is no current flowing because the PFET is OFF........then there can be no contact arcing because the contacts are already closed before current starts flowing?
Non arcing HVDC switch?
https://i44.tinypic.com/23wryba.jpg
