100kw dc motor driver circuit
carrier
Full Member level 5
Full Member level 5
Iran
100 kw dc motor
hi
i want to build a dc driver for electrinc motor with 100kw power.
anyone can help me?
thanks
dc motors 100kw
what`s the supply voltage?
leomecma
dc driver 100 kw
hi
without knowing any thing i think that you should the full bridge dc - dc converter since the power you want to deliver is higher than 500 watts .
best regards
dc motor 100 kw
100 kW is not "extremely high" powr level. IRG4PH50U (in the TO247 case) can deliver up to 50 kW in a step-down DC-DC converter
motor 100kw
input voltage 3phase 380 volt
output control needed 0 to 500 volt with current limit control
