abc123
Member level 4
- Joined
- Mar 28, 2002
- Messages
- 74
- Helped
- 3
- Reputation
- 6
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 575
working of plasma antenna
Plasma antenna technology employs ionized gas enclosed in a tube (or other enclosure) as the conducting element of an antenna. This is a fundamental change from traditional antenna design that generally employs solid metal wires as the conducting element. Ionized gas is an efficient conducting element with a number of important advantages. Since the gas is ionized only for the time of transmission or reception, "ringing" and associated effects of solid wire antenna design are eliminated. The design allows for extremely short pulses, important to many forms of digital communication and radars. The design further provides the opportunity to construct an antenna that can be compact and dynamically reconfigured for frequency, direction, bandwidth, gain and beamwidth. Plasma antenna technology will enable antennas to be designed that are efficient, low in weight and smaller in size than traditional solid wire antennas.
