Vanclair
Banned
The circuits I'm troubleshooting has a Momentarily output voltage at +1 volt on a good board
The problems with the bad boards is that the momentarily output voltage is not at 1 volt but .800 volts or .600 volts. some are 900 volts, etc.
The circuit has 10 stages of different gains of using LM741 op amps and different IC chips
Which IC chip is causing the momentary output voltage to not be at +1 volt?
What kind of troubleshooting can determine which IC is causing the problem?
I have been replace each IC chip one by one until i find the problem
How would you approach this type of problem?
The input is a switch and the output voltage rises momentarily to +1 volt on a good board
The Bad boards, output voltage rises momentarily to .600 volts to .900 volts
