10 bit ADC result to 8 bits?
M3GAPL3X
Junior Member level 3
adc result registers justified
Hi guys,
Quick question. What is the best way for me to convert a 10 bit ADC result (it uses two registers - ADRESL and ADRESH to store the results in either a left or right justified manner) into 8 bits? I will need to take that 10 bit ADC result and eventually send it over serial.
Any guidance would be much appreciated!
how to convert 10 bit result to 8 bit result
If you set your ADC to save the result Left Justified, bits 9 - 2 are stored in the ADRESH byte, so just use that, it also preserves bits 0-1 in ARESL.
You can see examples of what I mean in the chips datasheet.
n bit adc explanation
Thanks WP100 that makes sense. I'll go ahead and try it
adc result ,right justify
either left justify them, or right shift the 10-bit results by 2 bits.
    M3GAPL3X
16f687 diagram
Thanks guys. My question is, if I left shift them, I will have 8 bits in the ADDRESH register and 2 bits in the ADDRESSL register. Should I not care about the 2 bits in the ADDRESSL register?
usar el adc 10 bits con en el pic
Think you are missing the point about AdresH and L.
Don't know which chip you are using - not all datasheets give a clear explanation of adc justification - if you look up the PIC 16F887 datasheet - fig 9.3 on page 102 shows a clear diagram.
For the 8 bit result you just copy ADRESH to your working resigister - no need to shift or anything - the 2 LSBs in ADRESL are what you want to loose anyway according to what you said earlier ?
how to store 10bit adc in 2 registers
Thanks WP. I understand now. I will be using a PIC 16F687.
Thanks again!
