10 Best ways to code an FSM in verilog/VHDL
vipulsinha
Member level 2
Member level 2
Hi All
I am looking for any material/handout that describes the best effective way to code an FSM.
Like HUffman method, 2/3 process method and the rtl for the each method.
Thanks
Vipul
look into the following ....
h..p://www.asic-world.com/tidbits/verilog_fsm.html
there are a couple of papers at
h..p://www.sunburst-design.com/papers/
Added after 1 minutes:
also came across this ...
h..p://www.engr.sjsu.edu/crabill/vlogfsm.pdf
Also here is another example how to make a state machine in verilog
What about coding with case vs. if-else statements?
All the examples in this thread use the case statement for the next state logic. I would say this is the preferred way to code this logic since it will synthesize to parallel logic. An if else structure on the next state logic describe a prioritized structure.
Refer to Synthesis primer series books written by Bhasakr for VHDL and Verilog.
Amr Ali
AFAIK, when using case statements, the end result is a large MUX for all the cases that have to do a lot of switching. Using if-else eliminates this because you don't build up a large MUX. Can someone confirm this?
AFAIK, if-else if is equivalent to case statements logic wise. It depends on synthesizer manual how it will be synthesized.
Amr Ali
But I think the fundamental difference is the size of the MUX which is synthesized.
Yes, may be.
This is very synthesizer dependent.
BTW, it also depends on your coding style. Because some coding styles may add up some extra memories (latches, or FF's)
Amr Ali
