[SOLVED] 0805 library for altirum designer
baby_1
Advanced Member level 1
im using altium designer 10 for creating my PCB. now i want to create a smd board but my altium library doesn't have 805 component library.where can i download it?
I guess, your problem is to get familiar with the Altium tools and provided libraries. You just need to add the footprint to the standard chip resistor, provided in the misc. components library. Footprints are named by metric sizes in this library.
I just moved from Eagle to Altium. In Altium, I also don't find footprints for SMD resistors. I couldn't find any download button in the above link. Do I need to create footprints for each kind of resistors?
After installing the altium some libraries will be added.
Search for library in public documents.
I found the libraries. But there are very few components in the library. There is a library called Miscellaneous-devices.intlib, there are few resistors, and only SMD resistor is 0603. I need other packages.
I don't have the vault. Probably because of that I cannot see any download button there.
