Fragrance
- Joined
- Jul 26, 2002
- Messages
- 1,190
- Helped
- 248
- Reputation
- 496
- Reaction score
- 202
- Trophy points
- 1,343
- Location
- East Of Earth
- Activity points
- 8,933
Hi all friends
I have develop my on lab power supply making it feature pack along with power dissipation control for voltage regulator, two type of version I share here with current limiting and with out current limiting, after a care full test done for more then a month and found no problem in any manner so decided to share it for whole user benefit.
Main feature
keep the design simple and used common parts which can be found easily
Short circuit protection for input
Short circuit protection for output
Protection to voltage regulator’s
Out put reverse polarity protection
Supply voltage can be set down to zero volts
Current can be set down to zero amps
If you found any bug let me know for further improvements as I spent lot time to make it working as required a PIC micro based amps volt meter under trial and share soon under same topic.
regards
Fragrance
Due to mistake i uploaded initial work of my power supply full final version uploaded sorry once again
Main feature
regards
Fragrance
