Btrend
Advanced Member level 1
I have questions about the twin well process in 0.18um.
1. if it is really twin well process, then we can never faced the body effect problem of NMOS, if we always connect body to source, right? Of course, this will increase the area required .
2. if I use 0.18um 1.8V device , and always connect NMOS's body to source, then my Vgs=Vgb, then I can sustain more voltage at Vg with Vs > 0, for example Vs_min=0.5V. that is maybe I can use 0.18um device in Vcc =2.5V . But if the body Vb is connected to GND, then the COX breakdown will limit the available VCC, maybe only 2V or so for reliability issue. Am I right ?
Thanks in advance!
Thanks in advance!
